3018 cnc universal gcode sender
Results 1 to 5 of 5
Thread: 3018 cnc universal gcode sender
    Member Qbubbawm4mm's Avatar
    Aug 2020
    Default 3018 cnc universal gcode sender
    I have a 3018 and am trying to use Universal Gcode Sender. I have a DFX-Gcode file made with CamBam. The problem is when I load the gcode the project lands too far from the cnc machine. See circled object on attachment. How can I make it land at "X"?
    Attached Images Attached Images
    Member routalot's Avatar
    Dec 2003
    Default Re: 3018 cnc universal gcode sender
    Trying them all eh?How about going to the .dxf and moving the whole entity closer to the origin?Additionally,check the default units on all the software you are using.
    Aug 2020
    Quote Originally Posted by routalot View Post
    Yep I cant see spending a lot of money on really good software or good machine until I can get rid of my mental block on this issue.
    I have done all that. Created DXF in mm. Set everything to mm. Created drawing at page origin in AutoCad. Tried the same with other CAD programs (FreeCad, TurboCad) tried converting Inkscape to DXF, Tried directly generate Gcode from inscape.
    Anyway thanks for responding.
    Dec 2003
    I use Freecad and find it very good.Did your program run successfully when you used the simulation feature?Additionally,when you set the preferences did you go to units and select "metric small parts and CNC"?Then when you set the preferences for the Path module,which post processor did you choose?As i posted on the other thread about the problem pasting the first fifteen or so lines of the program here may provide clues.
    Aug 2020
    Actually I prefer AutoCad. FreeCad tends to quit responding on my machine a lot.
    Mike
