G-code Ripper
Results 1 to 5 of 5
Thread: G-code Ripper
    Default G-code Ripper
    May 2005
    canada
    Default Re: G-code Ripper
    Scorch is the authority but he won't spot this thread unless you contact him. His email is under the help tab.
    Why not simply ask the question ? You might get lucky.
    Anyone who says "It only goes together one way" has no imagination.
    Quote Originally Posted by cyclestart View Post
    Probe & cut wont save the file. Does anybody know why?
    Sent from my SM-N950U using Tapatalk
    May 2005
    canada
    The attached file saves as Probe & Cut using the latest g-code ripper tested in both Linux and Windows 10.
    If that file fails try a fresh download of g-code ripper.
    If the fresh download fails and no one else replies you may need to contact Scorch.
    ps: I don't know Windows well enough to know if a permissions problem is possible. I'll assume you know this stuff if you use Windows.
    Attached Files Attached Files
    Does anybody no what this means. It's an error I'm getting and I would like to fix.
    Sent from my SM-G781U using Tapatalk
G-code Ripper
G-code Ripper
