- problem G-code Ripper and mach3
hello, I hope someone here can help me, I have a problem using the G-code ripper with mach3, I configure the file and everything goes well until I do the test, start working the machine, do 2 or 3 tests and everything is fine but in a moment, it does not lift the Z axis anymore, it only continues towards the next test point but without raising the Z axis and it gives me an error and I can no longer continue, does anyone know why this error is due and how can I solve it?
- You may not post replies
- You may not edit your posts
Forum Rules
