It sounds like your design tool paths extend to a minimum X value of -0.1 and a minimum Y value of -0.6.
G-Code Ripper can adjust the origin for you if you want it to. To adjust the origin you just set the Origin setting to Bottom Left ("Bot-Left") then the zero position will be at the bottom left corner of the design. Beware, if you do this and then do a subsequent operation like drilling the holes may not line up because you are asking G-Code Ripper to adjust the origin position.
