Dxf2gcode question...?
Results 1 to 4 of 4
Thread: Dxf2gcode question...?
    CBaxter's Avatar
    Mar 2019
    Question Dxf2gcode question...?
    Does anyone here know anything about dxf2gcode? There appears to be no help or instructions on the web - the wiki page just lists the headings of the parameters without specifying what they do.
    In particular, I am having problems with the Z axis. The generated G code makes the Z axis go up and down like a yo-yo. There are several parameters in the set-up:
    1 - Retraction Co-ordinate
    2 - Safety Margin
    3 - Work-piece origin Co-ordinate
    4 - Slice Depth
    5 - Final Mill depth
    I guess that these refer to
    1 - Height that the tool can move at
    2 - ?
    3 - height of top of work-piece
    4 - depth for each slice
    5 - maximum depth that tool should go.
    But when I fill these in with sensible figures, the Z axis seems to rise and fall by varying amounts which seem to depend on a calculation using these figures. I am doing a simple 2-D cut, I simply want the tool to retract to -10 for movement and drop to -14 for cutting (absolute). What should I fill in to achieve this?
    Member he1957's Avatar
    Jun 2018
    Tasmania
    Default Re: Dxf2gcode question...?
    Haven't used it personally and as you say, doesn't seem to be a lot of information for this.
    There is a user guide at: https://sourceforge.net/p/dxf2gcode/...e%20DXF2GCODE/
    which also has a link to a user forum.
    If your intent is to read DXF files and generate GCode, there are other options.
    A lot of folks use Fusion 360, vCarve [Pro] and there are others:
    Have a look at some of these:
    SimplyCam: MR-Soft Nc Software Tools
    GrblGru: The Author does not have a web site but the software package is very interesting: https://www.dropbox.com/s/278a8a5uu9...anual.pdf?dl=0
    A few samples of Linux tools: LinuxCNC Documentation Wiki: Simple LinuxCNC G-Code Generators
    Is there something specific you are trying to do?
    Member JTUT's Avatar
    Feb 2020
    I simply edit the g code in text file. Do a find and replace for the z position.
    Member routalot's Avatar
    Dec 2003
    I must admit to looking at Dxf2gcode some years ago and I thought it was great to be able to take the shape I wanted,offset it by a cutter radius and then tell the program to produce the Gcode for the shape that resulted.At the time I didn't have a home machine.These days I do and I use Freecad to model my parts and then use the Path workbench to generate the code.It works every time and if I change anything,it regenerates the toolpath almost instantly.
