Me again.
Back home from work, I tried some other test. I took some pics to better describe the problem.
Pic1
This is the original vector during the CAM process. As you can see, I set the origin in the center. This test job is divided in 2 codes: the first just for the labels and the graphics, the second for the cutting paths.
Pic2
This is Gcode ripper windows concerning the first code (the labels and graphics) with the probe offset. The first issue I can see is the origin: in the CAM is quite more upward considering the number "2" in the middle-down portion, while in Gcode ripper window the same number is in the up-right portion.....
Pic3
This is the webpage https://ncviewer.com/ (I check the code online here). The code loaded is the one created by CAM software. The number "2" is the right position
Pic4
This is the same webpage, but the code loaded is the "probe 'n cut" generated by GcodeRipper: a mess....
Pic5 and Pic6 are concerning the second code (the cutting path) in GcodeRipper and on the web simulator: same issue......
Beside the problem with the corrupted (?) code generated by GcodeRipper, the issue with the origin is considerable: after changing the tools to execute the second code, the labels and the cuts won't correspond anymore....
Andrea
