Mach3 G-Code-Ripper not working
Results 1 to 5 of 5
Thread: Mach3 G-Code-Ripper not working
    madmac4u's Avatar
    Oct 2018
    Exclamation Mach3 G-Code-Ripper not working
    I have 4-axis 6090 CNC from china,
    i am using "G-Code-Ripper" to work with uneven surface copper pcb.
    but when i run the file.ngc file in mach3 the output in the file gives similar values for each axis,
    though while running the probing it shows proper Z values on Mach3 interface.
    the output file looks like this
    54.97500,21.67500,-0.03750
    Please help me find out the problem.
    Thank You.
    Dec 2016
    New Zealand
    Default Re: Mach3 G-Code-Ripper not working
    Hey, did you ever receive a fix for this. I have a similar issue if the board is very closely level. If it's a lot out of sync then the output file seems to work,
    Member he1957's Avatar
    Jun 2018
    Tasmania
    Try lowering the accuracy values in General Settings.
    Nov 2017
    Portugal
    did you ever receive a fix for this?
    Member scorch's Avatar
    Dec 2010
    Quote Originally Posted by madmac4u View Post
    Thank You.
    This is a problem with MACH3 and/or the controller board you are using. Other people have reported problems like this. At least one fixed it by upgrading the firmware on the controller.
    I don't use MACH so I don't know more than that.
    Scorch
    www.scorchworks.com
