From your description I am assuming you are getting the following error:
"" Entry Error Detected: Check Entry Values in General Settings Window ""
Open the General settings window (Select "Settings"-"General Settings" to get there), then look to see if any of the input fields are colored red. If one is red that is where the error is coming from.
Let us know if you find the problem.
