- Fanuc Robot CAM program
Re: Fanuc Robot CAM program
Hi mr. Adder, I just recently found your post and is really interesting, I have a question about one of your programms, in your program Robot path translator v3.0, on the top I see a comm port settings, are these controls working for a fanuc robot? like a rj2?
thanks and great work.
hello Mr Death Adder , I see you understand a great deal about fanuc robots , and if you can give me a hand , thank you very much!
the company I work for bought a s420iW with a fanuc controller RJ2
and would like to control the robot to do 3d printing 3d machining or through code files converted to g . tp , but found nothing specific , I know you have much experience in the matter .
I thank your attention .
Death adder Hello , I have a huge appreciation for your help here in the forum , and I am also interested in this program that you wrote in this state where the program ? I wait for some contact her , even more.
Thank you .
Hi Dear Death Adder
We have a Fanuc robot S-420if too, and I want to convert .dwg, .dxf and ... file format to a .tp format(in matlab or c#...).
Can I use this code for it!?Is this need to change or not?
thank you for your attention.
Use Roboguide for import your *dxf. In this program you will create *tp for robot
Hello Engineers
I am trying to load a.LS file that I have created by using slicing software, and I want to load it into Robot Guide, but I keep getting this error message:
"The ASCII-to-binary translation may have failed." If someone has come across this issue and wishes to share their solution, it would be appreciated.
For more explanation:
I created both LS files by using a slicer, and I want to upload them to a robot guide and teach pendant just to perform offline programming, so I got the above-mentioned error. and my purpose is about additive manufacturing project. Thank you all in advance for your assistance.
hello Dear Death adder
Happy 2024 year to you and your family .
I have a fanuc robot with R30i B mate plus controller .
I don't know anything about c++ or other programming language .
How I may use your fanuc program translator ?
In fact I need to prepare programs in G-Code and then translate it to TP language .
if it is possible with your translator please Help me to do that.
my email is majidtaherkazemy@gmail.com .
I appretiate and will compensate your helps .
Sincerely Yours
Majid
- You may not post replies
- You may not edit your posts
Forum Rules
