G-Code Ripper - Scale, Rotate and Split G-code - Page 4
Page 4 of 6 FirstFirst 123456 LastLast
Results 61 to 80 of 113
Thread: G-Code Ripper - Scale, Rotate and Split G-code
  1. #61
    Apr 2013
    Default Re: G-Code Ripper - Scale, Rotate and Split G-code
    Lookie here! G-Code mirroring code. https://github.com/bkubicek/grecode
  2. #62
    Oct 2012
    Santa Fe, Tx...USA
    This is just what I have been looking for. I have a customer who wants to engrave a logo in a gunstock. I was thinking of putting aluminum foil tape (the sort used for sealing a/c ducts) on the gunstock and using the tool tip as the probe grounding the tool setting puck to the foil tape. I have yet to try it out but am anxious to do so. Thanks, scorch for coding this software. I found this through the CNC Coockbook blog.
    Bob
  3. #63
    Sep 2005
    I built an additional type probe using a momentary switch. No matter what kind of material I probe now, it works. And there's no glue residue to clean up.
    Sent from my VS990 using Tapatalk
  4. #64
    Registered jfong's Avatar
    Apr 2004
    I tested his probing software when he first announced it. I made a probe with a switch inside. The software worked perfect. I also used his software to wrap gcode for 4th axis rotary. Great piece of software.
  5. #65
    Oct 2016
    Germany
    Hello,
    i have a Little Problem with the Output from SolidWorks.
    G-Code Ripper gives me 3 Errors which i have to correct in the G-Code before i can load it into the Ripper.
    1. O Codes are not supported
    2. A Codes are not supported
    3. D Codes are not supported
    After deleting this codes i can finally load the file. Hopefully i did not delete any important Things from the original Code. ( i am new in CNC Milling )
    Also there is a black command window all the time. What is that for and can i start the Ripper without this window?
    Would be great to have an answer...because this is a very great Programm !!!
    Matthias
    Attached Files Attached Files
  6. #66
    Member scorch's Avatar
    Dec 2010
    Quote Originally Posted by mroschk View Post
    1. I am not clear on what the O code at on the first line of this file is doing. Usually I see O codes with a keyword after them (sub, repeat, etc). This O code does not seem to be doing anything so you are safe deleting it. (Maybe someone smart will tell us why it is there.)
    2. The A codes in the file indicate A-axis movements The code only sets the A-axis to the zero position two time so you are safe deleting these also
    3. The D code sets the tool diameter for the tool that is selected. There is no tool compensation called so you are safe deleting this one also. (The G40 explicitly turns it off)
    I make G-Code Ripper stop processing on these codes to force the user to bypass them if needed. I would rather make the user makes the decision. There might be settings in Solid works to get rid of these unneeded codes.
    The extra black window is an artifact of the way I produce the Windows executable. You can pretty much ignore it. You can run without the black window by installing Python on your machine and running the .py file directly. I don't recommend that because I don't want to have to support people getting python running and the way I package the executable files they run faster than a standard Python install would run.
    Scorch
    www.scorchworks.com
  7. #67
    Oct 2016
    Germany
    Hello,
    thnks for the fast Answer!!
    Maybe the O-Codes Comes from the Postprocessor i use. It is called "PostDevTestMachine.vmid" and "PostDevTestMachine.gpp".
    I think i found it here, or maybe somewhere else.
    But i also tried other PostProcessors in Solidcam. There are also These O-Codes inside the final Code.
    It would be very GREAT if you could do some changes in your Ripper,
    an Option for the user to self decide to let the Ripper skip the O, D and A codes.
    It would be very great if you could do that and recompile one Windows Version without the Debug Window.
    Would be great of you...Thanks
    Matthias
  8. #68
    Oct 2016
    Germany
    ...i have an Additional question and here some better explayin what i mean.
    Attached is a Picture where you can see my Probe.
    When i move the Z-Axis down until the Probe just touches the Part i have a Z-Value of ...lets say -10.000.
    That is the Position of the Probe you can see in the Picture.
    But the Wires of the Probe are not closed at this Moment.
    To Close the wires i have to move the Z-Axis around 2.5mm down.
    So, what Value have i to put in to the "Probe Z Offset" in the Ripper ? ( -10.000 or -12.500 )
    MAtthias
    Attached Images Attached Images
  9. #69
    Dec 2010
    use the -12.500 value.
    Scorch
    www.scorchworks.com
  10. #70
    Oct 2016
    Germany
    Hello,
    ok, i will try that this eve when i am back home.
    Can you say something about the other question i ask you?
    Would be great, because i had yesterday, as example, a *.TAP file with a very lot of D1 Values....
    Greetings and Thanks
    Matthias
  11. #71
    Apr 2013
    I'd still like to see this able to mirror image G-Code, while keeping the same movement direction so regular milling doesn't switch to climb milling, or visa-versa.
  12. #72
    Dec 2010
    Quote Originally Posted by Galane View Post
    I think about the potential mirror option sometimes but getting it to work right with the milling style (climb mill vs. conventional) make things complicated. Running the tool path backwards to achieve the same cut style could be disastrous. I am not sure how it would be possible to get the cuts correct.
    Scorch
    www.scorchworks.com
  13. #73
    Dec 2010
    You might consider making a copy of the post processor files and edit them to fit your need. I am not familiar with the format of Solidcam files but generally post processor files are reasonably easy to edit especially if you are only looking to suppress some specific commands.
    I might change the behavior so the errors can by bypassed but I am not planning on working on that anytime soon.
    Scorch
    www.scorchworks.com
  14. #74
    Oct 2016
    Germany
    Quote Originally Posted by scorch View Post
    Hello
    i anot firm enough to edit the PostProcessor, sorry.
    That means you will ot Change thins in the Ripper?
    That would be too bad !!
    Matthias
  15. #75
    Oct 2012
    Santa Fe, Tx...USA
    You are asking a bit much for some freeware. Mirror in your CAD/CAM.
  16. #76
    Feb 2009
    Bulgaria
    Hi scorch,
    Trying to migrate to Linux as much as possible. Installed the dependencies and ran the .py file (Ubuntu). And surprise - it works
  17. #77
    Oct 2012
    PT
    Greetings Master
    Do you have the code on the github?
  18. #78
    Dec 2010
    Quote Originally Posted by X3msnake View Post
    Greetings Master
    No. The source code is readily available at www.scorchworks.com
    Scorch
    www.scorchworks.com
  19. #79
    Mar 2008
    Bg
    No. The source code is readily available at Scorch Works
    when I try to download a Windows version, I receive this error:
    "Gateway Anti-Virus Alert
    This request is blocked by the Firewall Gateway Anti-Virus Service. Name: (Cloud Id: 44893176) MalOb.GX (Trojan) blocked."
    Do you know why?
    Regards
  20. #80
    Jul 2009
    NL
    I thought to give gcode ripper a try but I get this error:
    ERROR EXP-3: Unable to evaluate expression: [/2]
    For all the versions listed on your website.
    In this case on a virtual machine with ubuntu 12.04 as well as on my main machine, budgie 18.04
    Is that a bug or am I doing something wrong?
    Sven http://www.cnczone.com/forums/diy-cnc-router-table-machines/320812-aluminium-1250x1250x250-router.html
