Hi, I built the card, now I have a configuration problem, I have the 200-step motor directly coupled to an axis of 1.25 mm pitch as I configure the parameters of the engine, thanks a lot sorry for English are Italian , Gianfranco greetings.
Isn,t any sources (not .hex) of this project - i am not PIC fan, i think that
porting it to AVR will be interesting .
sorry. I've found it.... but PICBasic to WinAVR -- not a light and fast way ///
Hello to all,
I made the Arnauld CNC Controller.
Everything seems fine, the motors move, but I cant load any gcode into the device.
I think that the error are in the SD card filesystem, or the file name itself.
Could someone give me a help how do you load the gcode in the device?
Thank you very much.
http://www.cnczone.com/forums/open-s...ml?#post599749 in *.zip file
hi all
if i want to make this cnc controller then where i fount its material. hardware and software.
shabbir
Any eagle cad files here
This is another Full controller >>> with lcd also>>>
Wow. Anyone speak Russian? It would be nice to understand what compiler he used, etc...
James hosts the single best wiki page about motors for CNC hobbyists on the net:
http://techref.massmind.org/techref/io/motors.htm Disagree? Tell him what's missing! ,o)
Good afternoon.
Help me fix a bug in the program.
I gathered this device on the breadboard on pic18f4620.
Like the way it works, only doubles the menu arrow (CNC PARAMETERS)
when choosing between paragraphs (TABLE / SPINDLE).
And this error in all versions on pic18f4620 and it can be seen in Proteus.
Maybe someone will be able to recompile the source code to fix?
Who will tell me how is the recording on MMC MC56U032NCFA-QC ?
Something I have not saved anything. Connected using a formatted FAT32, and she
as it was empty because it does not have the coordinates.
Tell me who is working you need to create one.
HOLA ESTOY HACIENDO UN PROYECTO PARECIDO PERO CON EL PIC 18F4550 AUN ME FALTA MUCHO LO QUE RIA PEDIR CUANTO COSTARIA QUE ME FASILITE EL CODIGO photo_2021-08-30_17-05-13.jpgphoto_2021-08-30_17-04-41.jpg
