My LCD BG12864E(Bolymin) now is working with new Arnaud CNC .
Thank you!!
L-am facut eu dar inca nu am legat la el driverele pentru motor sa vad cum se misca
Thank you!!
So, until now two persons have build this controller. Also it seems that displays like 12864 are working.
Vasyl - did you connected it to a machine ? Did you succeed to run a G-code ?
Keep us informed - maybe some pictures ?
Daniel
The New Arnaud CNC from (http://www.usinages.com/controleur-a...-t2415-75.html ) is working with UHU servo controller . With the help of Arnaud I was run G-code file :
G00 X100 Y10 Z5
G01 Y20 F13
M03 S2000
G01 Z20
G00 X0 Y0 Z0
G01 X10 F21
G01 Y10 F22
G01 Z0 F23
G01 X123 Y321 Z0 F24
M05
M02
But non-uniformity of movement is observed. Impulses on the controller go packages with a pause. I yet have not tested the command G02 and G03 .
Vasyl Markiv
Photo of Arnaud CNC with UHU servo .
Thanks for update and pictures Vasyl.
I am planning to build myself Arnaud controller.
From your pictures I see that you had the same problem that I have found : my display doesn't have the same pinout like that one of Arnaud.
TEsting with a stepper motor would spot maybe better if it is a controller or driver problem.
What was the problem when you needed Arnaud's help ?
In cnc.zip there are files of printboard in *.pdf , *.gif and SprintLayout format and gcodetxt . In arnaud.zip is an example of Proteus file for emulation ArnaudCNC . With a stepper motor you will feel a pause between packages of impulses . I think .
Arnaud's projects and are very well made and thought over, they are easy for understanding . Arnaud was help me with a LCD , format of Gcode file , and ...!!!
Best regards
Vasyl Markiv
What version of Proteus you used? (7.2 or 7.3)
Regards!
S.M.
Proteus 7.4 SP3
Vasyl, thanks!
I am tested on Proteus 7.4 and it's ok. Next mont I will made board for test on cnc-mill. After that I will post here and Usinages about that.
Regards,
S.M.
Crystal is 40 Mhz , fuses in *.hex file .
arnaud2 Nice work and thanks for sharing some of the information with us.
Regards
Bart
hello world
I too have built
but the movements are only those running with the keys
mmc card with makes all movements at random layers
and non-uniform
however I have seen on youtube who made the new version and it seems that works
http://www.youtube.com/user/arnaud9173
http://www.youtube.com/watch?v=HLuTF0bYsy0&eurl=http%3A%2F%2Fwww%2Eyoutube%2Ecom%2Fuser%2Farn aud9173&feature=player_profilepage
ARNAUD what have you done?
where are you?
the end the project or you have left?
however, thanks to the work you have done until now
PS:
sorry my English
but ITALIAN
could you give code for g02 and g03
thanks
Great job!!!!! and thank you for all arnaud2, but please, help me -> describe routines for aceleration, setup velocity, acelereation and pulses . I don't understand that. I like theory for this or references.
Thank you very much,
greetings
Hello! The help is necessary to me. A problem with the display. How it can be corrected? Thanks.
http://www.usinages.com//files/gluuk_182.jpg
hello
must reverse the CS1 with CS2
the dispay
Thanks!!!
And who knows something that the author? he threw the project? or discussion shifted to another place?
