BLDC driver using STM32F103
Results 1 to 3 of 3
Thread: BLDC driver using STM32F103
    Member Radzins's Avatar
    Nov 2020
    Default BLDC driver using STM32F103
    Hello to everyone here.
    I recently stumbled upon very good project here:
    https://www.cnczone.com/forums/open-...28-cnc-24.html
    It seems that this thread was closed long ago .
    I am a hobbyist in electronics. Have made some small projects using Arduino. I made a working small CNC router using Arduino UNO and stepper motors.
    Now Im trying to make bigger CNC which will need higher feed rates. So I was searching for BLDC servo solution, and found it hare.
    This looks like realy good project to implement cheap BLDC motors for motion control.
    Anyway, I started to make this project.
    MCU is conecting to Servo Tuner app
    the app is showing encoder position
    But, I decided to test signal to driver stage and I get weird results. pins PB15, PB14, PB13, PA10, PA9, are HI, and PA8 is LO. This will result in magic smoke if I connect MOSFETs.
    I plan to use FDD8896 MOSFETs and drive them dirrectly from MCU. Allready tested to switch them dirrectly and works just fine.
    So can someone please help me hare?
    Attached Files Attached Files
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: BLDC driver using STM32F103
    Are you sure you have steady HI level on those pins (not high frequency PWM)? Did you check it with a scope or just a voltmeter?
    Nov 2020
    Quote Originally Posted by CitizenOfDreams View Post
    Actually I checked with scope too. It gives 5 Hz with 0.8 v drop. So steady hi.
