PIC Open source Servo Driver Schematics development? - Page 8
Page 8 of 8 FirstFirst ... 5678
Results 85 to 91 of 91
Thread: PIC Open source Servo Driver Schematics development?
  1. #85
    Jul 2009
    uaz
    Thumbs up thanks
  2. #86
    Aug 2009
    Vietnam
    Tôi mới bước đầu tìm hiểu về máy cnc, xin các đàn anh chỉ giáo
  3. #87
    Jul 2005
    Italy
    just redrawn schematic and PCB on Eagle.
    I added 5v from motor supply, and the layout is made for rack mount.
    Naturally TIP112 must be mounted behind PCB on alu plate.
    I hope can be useful
    Attached Files Attached Files
  4. #88
    Apr 2004
    So is this a servo driver or a stepping motor driver? granted I have not gone threw all of the posted pages but still I'm wondering? Last I knew lini stepper was an opensource stepping motor driver
  5. #89
    Registered James Newton's Avatar
    May 2005
    berin, you are absolutely correct. The Linistepper is a stepper driver, not a servo driver. This thread apparently took a turn... LOL.
  6. #90
    Sep 2011
    West Bank & Gaza Strip
    Lini8 charge-pump modification appears to work only for Linistepper Version 1, with Enabled is High. In Linistepper Version 2, however, Enabled is active low. Any suggestions on how to make Lini8 modifications work with Linistepper Version 2? Best regards.
  7. #91
    Sep 2011
    Quote Originally Posted by agelkom View Post
    Hi Argun,
    Some components are mising in your component list (IC4, IC5, R11A, R12A, R46, R50-R52). Can you post full component list? Also I found discrepancy between schematic and pcb. In schematic resistor R51 attached to pin 4 of IC5, on pcb to pin 3. Can you check which is right?
    Regards,
    Romas
    Hi Romas,
    Sorry,
    Component list attched.
    R51 an IC5's photo diode are in series, there is no difference R51 position. The differences may occur during PCB drawing.
    Regards
    Argun
