open source Atmel/arduino PID motor control - Page 21
Page 21 of 21 FirstFirst ... 1118192021
Results 241 to 249 of 249
Thread: open source Atmel/arduino PID motor control
  1. #241
    Member KOC62's Avatar
    Mar 2009
    Default Re: open source Atmel/arduino PID motor control
    That certainly is not right. Your zero cross detector is suppose to sync with your line freq. Are you triggering your 'scope to the line freq? Else it will stay the same if it triggers with itself.
  2. #242
    Dec 2014
    No, my scope doesn't support such high voltage.
    The signal shown previously is the Arduino's input.
  3. #243
    Mar 2009
    I would use the Arduino input (ZC) to also trigger your 'scope and then 'scope your pulse output of the Arduino, which should move position with pot rotation.
  4. #244
    Dec 2014
    I am afraid I don't know how to do that.
  5. #245
    Mar 2009
    Have you used EXT trigger?
    Must be a front panel jack for an external trigger. You would this jack to connect to the ZC signal going to your Arduino input. Then set your trigger mode to external. You monitor on channel 1 (or 2) the Arduino output pulse.
    I don't have your type of 'scope so I can't give specific steps to follow.
  6. #246
    Dec 2014
    Oh I see !
    The pulses are fixed when the pot is at a low value (around 100) but are scrolling when I raise it.
    open source Atmel/arduino PID motor control-img_3459-jpg
    Attached Images Attached Images
  7. #247
    Mar 2009
    So the pulses do move relative to the zero crossing signal. The next step is to figure out why the motor doesn't change rpm with the pot change.
  8. #248
    Jul 2019
    Taipie
    Hi all,
    this project have a protection about motor stuck or over current or not?
    Thanks.
  9. #249
    Mar 2009
    The protection is a fuse in the motor wiring. The fuse should be sized such that if the motor stalled the fuse will blow. This fuse amperage selection will vary depending on the motor selected and its current ratings.
