Being the manufacturer, we don't have such issues. Where are you, what color and material would you like? Brushed aluminum is the only real finish as the other metal looks are just paint. After seeing your creativity, I was think of stacking 2 together with the wires laid between them. Or use small zip ties to hold the wiring down though your clamps are resourceful.
I think it wouldn't work to stack 2 blinds together. The trick to get it to work properly are the spacers I have under the ties across the cables. If the spacers are to tight the cables bind and dont allow proper movement and if are too loose the cables come out to the sides. The spacers must be just right to hold the cables a bit tight but also allow a bit movement.
I'm in Canada, thanks for the offer but I have enough blinds to last me for ever LOL. I replaced all the blinds when I bought the house and kept all the old ones, but they all are beige and I went to the store to get plain aluminum color; no problem I just use paint remover and they come out pretty good.
