Originally Posted by
victorofga
tcnc..
I used these slides for drawers.. they are working very well as drawerslides..
if you like ot use as cnc machine part, then use it.. good luck
if youask our opinion, then we will give it..
you don't have to take it..
if you feel this is the cheap way, designing a year long using high end engineering program, using great quality aluextrusions and all other just from hardware store lower shelves,, then go ahead..
but don't expect we can find a way you, get working a drawer slide likely hiwin rails are working..
theres no way.. (simple way)
me and thoushands others, can write down how it will work, before you just pull a line even on a paper, before you buy parts, before you build this..
you don't have to trust us.. go on your kung-fu way and build it..
we all don't benefit neither way..
you follow we saying or you ignore we saying..
so good luck with your building.. this is not cheap way you making..
still I keep my opinion about the cheapest way.. what means if I buy something later I can use yet.. these drawer slides only good throwing neighbor dog when it wants to bite you :-)
