1530 Spindle Beeping / Warning
Results 1 to 3 of 3
Thread: 1530 Spindle Beeping / Warning
    Activation process matthewomeara's Avatar
    Dec 2018
    Default 1530 Spindle Beeping / Warning
    I have an OMNI 1530. Just now the spindle started beeping, which I assume is a warning of some sort. I don't see any documentation on it in the OMNI manual. I'm not sure if this is a warning that the OMNI folks programmed into the spindle, or if it's a warning that is native to the HSD ES951 spindle itself. It's a constant beep and the #2 and #3 lights are on on the spindle.
    I couldn't seem to find a manual on the HSD site. Thanks for any help.
    Jul 2020
    Default Re: 1530 Spindle Beeping / Warning
    I am an omni cnc after-sales engineer, please contact me whatsup. Please send me a video or photo. I will check for you. My whatsupID + 8618621877020
    Thank you
    Alan sun
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by matthewomeara View Post
    If you have a tool changer check that the air pressure is correct and the tool change prox switches are activating correctly
    Mactec54
