- Need Help!- Omni X8-2200 or 1500 for birch plywood
*Registered User*
Hi guys,
I'm willing to buy a CNC and i found the omio looks great
So, i want to cut birch plywood, which is fairly dense, that's why i didn't end up with an x-carve or an OX. So, i'm thinking about the 1500 and 2200 model, what depth of pass and speed will i have with the 1500 model ? And the 2200 ? How can i calculate this ? I want to use 6 or 8 mm drill.
https://www.omiocnc.com/products/x8-...-engraver.html
https://www.omiocnc.com/makerzonelis...-engraver.html
Thanks a lot,
Dimitri.
PS : BTW, i'm reading that the 4 axis is not that great on this machine, it was in 2015 from what i've read, between theses 2 model, one is ok to work with ? 4-axis version(with H60-axis) +US$315.00
4-axis version(with AH60-XX80M-10) +US$420.00
Re: Omni X8-2200 or 1500 for birch plywood
Thiis Omni cnc , not Omio cnc , kindly notice the difference .
- You may not post replies
- You may not edit your posts
Forum Rules
