Need Help! Hanqi 2.2kw atc spindle
Results 1 to 5 of 5
Thread: Hanqi 2.2kw atc spindle
    Jun 2015
    Default Hanqi 2.2kw atc spindle
    Hi everyone
    I have the above spindle attached to my Omni 1325 machine.
    Firstly I have to say this machine has been a dream to use and has been very busy indeed.
    However now I'm in a real panic situation. I thought I'd covered all bases but didn't and hands up.
    I have two of the above spindles, one as original an one is new spare replacement. The original has been developing an intermittent fault whereby say half way through a cut file the space spindle reports that it is "without tool".
    So I decided to change the spindle with the spare that I purchased from Omni around 5 months ago.
    It's all connected up, however it doesn't allow a tool insertion and feeds back to the controller that the clamp and unclamp has failed.
    The trouble is I don't know the details of how it operates but I'm guessing it's a diaphragm / push action that operated the holders clasp.
    This is not moving at all as if it is seized ?
    Anyone had any experience whatsoever of this spindle?
    I have the model reference
    Member mactec54's Avatar
    Jan 2005
    Default Re: Hanqi 2.2kw atc spindle
    djcregan
    You must have a water trap with air filter also close to your machine, to keep these tool changes in good shape
    Did you swap the air connection ports around and try it again
    They have a Piston just like a normal air cylinder
    You could also check to see if you have air coming out of the tube that goes into the spindle, when you press the tool change button, if you have no air then you will need to check the control valve
    Mactec54
    Jun 2015
    djcregan
    Hi
    This is the brand new spindle, but yes there is double air filter.
    Yes the piston isn't moving at all, is as if it's seized.
    I don't know why other than being stored in my factory for a few months but humidity isn't extreme ate all.
    Also
    The original spindle is still running fine except that it is giving a warning signal to the syntec controller that there is no tool in the spindle. This happens intermittent during cutting.
    Any ideas ?
    Jan 2005
    Quote Originally Posted by djcregan View Post
    Hi
    Also
    Any ideas ?
    Have you run this new spindle at all
    Mactec54
    Jun 2015
    No
