Need Help! What post processor to choose for Omni cnc using Aspire??
Results 1 to 8 of 8
Thread: What post processor to choose for Omni cnc using Aspire??
    Feb 2017
    Chile
    Lightbulb What post processor to choose for Omni cnc using Aspire??
    Hi, anyone knows what post processor to choose from Aspire to create .nc files for 1325 Omni CNC Router??
    Thank you.
    Aug 2009
    Default Re: What post processor to choose for Omni cnc using Aspire??
    Which controller, that's more important.
    Sent from my LG-D852 using Tapatalk
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
    Feb 2017
    Chile
    Hi thanks for your reply.
    I am very new to cnc so i am not sure how to get the controller specificaction.
    Please find attached the description of the machine, maybe it helps:
    1 OMNI 1325 Basic CNC Router with 6.0kw HSD spindle
    X,Y,Z working area: 1300*2500*200mm
    Drive and motor: Yako drive and stepper motor
    Table size: 1500*3040mm
    Spindle: 6.0kw, Italy HSD aircooling spindle, 0-18000RPM
    Inverter: Fuling frequency inverter
    Spindle Protection Device: Selfcooling for aircooling spindle
    3.0kw Dust collector with 2 cloth bags and Dust hood
    Bakelite table combined Aluminum T -slot extrusion,vacuum table
    Mist Oil Sprayer for Aluminum
    X, Y, Z Travelling Potioning Accuracy: ±0.05mm / 300mm
    X, Y, Z Travelling Repositioning Accuracy: ±0.05mm
    Frame: Big thickened Steel Square Tubes, thickness up to 8mm
    X, Y structure: Helical Rack and pinion drive, Hiwin square rail linear bearing 20mm
    Z axis structure: Taiwan TBI ballscrew and Hiwin square linear rail 20mm
    Max Rapid Travel Rate: 32,000mm/min
    Max working speed: 20,000mm/min
    Working voltage: 220V, 50Hz
    Command languages: G code
    Control system: DSP remote controller
    Software: Ucancam V10 English version
    Limit stop: Extra-travel limit stop and hard limit stop
    Emergency stop and Switch: Japan Omron emergency stop and SCHNEIDER switch
    Package: In wooden box : 3200*2100*1900mm(12.77CBM)
    Gross weight: 1950KGS
    Aug 2009
    So you have a dsp controller, and you'll need a dsp post. Look for Rusty in the omni sub forum and send him a pm or email me if he doesn't respond. He's got a dsp controller and I have his email if he doesn't respond on cnc zone.
    Registered RUSTY2's Avatar
    Jul 2013
    Quote Originally Posted by Alvaro_Lebtek View Post
    Thank you.
    I have a Omni Pneumatic Tool Change 1530 with a 4th axes I have a A55 DSP Controller I use MODEL MASTER ATC INDEXTER (mmg) as a post processor . hope this helps
    Member Aceline's Avatar
    Feb 2021
    Does anyone know what post processor I need for Omn-1325 cnc, I am using Artcam Pro
  7. #7
    Feb 2021
    Does anyone know what to use for the Omni-1325 using artcam?
  8. #8
    Aug 2017
    China
    NC studio ATC
    test it
    What post processor to choose  for Omni cnc using Aspire??-d4a1cc785b8336333d987f08fbca90d-png
    Attached Thumbnails Attached Thumbnails What post processor to choose  for Omni cnc using Aspire??-d4a1cc785b8336333d987f08fbca90d-png
  9. #9
  10. #10
    Valkop's Avatar
    Feb 2024
    Great! Thanks for sharing it's a valuable info
  11. #11
    malansanni77's Avatar
    Apr 2024
    Quote Originally Posted by Aceline View Post
    Does anyone know what to use for the Omni-1325 using artcam? fnaf
    ArtCam adalah software CAD/CAM yang dapat digunakan untuk mengubah gambar 2D atau 3D menjadi file gambar kerja yang dapat digunakan oleh mesin penggaruk atau mesin pemotong lainnya. Pastikan Anda memiliki versi ArtCam yang kompatibel dengan Omni-1325.
