Points (for spline) from file
Results 1 to 2 of 2
Thread: Points (for spline) from file
    Registered DMC80U's Avatar
    Sep 2003
    Sonthofen
    Hello guys!
    I’d like to construct a NACA profile via spline.
    Therefore I’d like to get points from a .dat file.
    What does the formatting in .dat have to be like?
    Thanks in advance
    Registered Traori's Avatar
    Oct 2004
    Andelfingen
    Hello
    It’s described in the documentation and context help:
    Each point is described with its XYZ coordinates. The values are separated with tabulators or spaces.
    There are 3 kinds of point files:
    -sequence of points
    -sequence of points with rake and curves
    -series of points
    Example of a sequence of points:
    Code:
    1.00000 0.00000 0.0
    0.99655 0.00039 0.0
    0.98649 0.00174 0.0
    0.97049 0.00427 0.0
    0.94916 0.00778 0.0
    As already said, you’ll find other information about “points from file” in the documentation.
