DIY Aluminum cnc router Frame
Page 1 of 74 12341151 ... LastLast
Results 1 to 20 of 1474
Thread: DIY Aluminum cnc router Frame
    Member gio666's Avatar
    May 2008
    Default DIY Aluminum cnc router Frame
    20x36 Frame 1/2 Aluminum
    20" end frame
    15" Y uprights
    2 36'" Aluminum profile
    1 20" Aluminum profile
    4 16mm bearings and housing
    4 20mm bearings amd housing
    2 36" X 20mm Linear rails
    2 20" Y 16mm Linear rails
    6 mm bolts
    $ 450
    30x48 Frame 1/2 Aluminum
    30" end frame
    17" Y uprights
    2 48'" Aluminum profile
    1 30" Aluminum profile
    8 20mm bearings and housing
    2 48" X 20mm Linear rails
    2 30" Y 20mm Linear rails
    6 mm bolts
    $550
    Ship Anywhere
    Attached Thumbnails Attached Thumbnails DIY Aluminum cnc router Frame-cnc-058-jpg
    May 2008
    Complete frame
    Attached Thumbnails Attached Thumbnails DIY Aluminum cnc router Frame-cnc-064-jpg
    May 2008
    Complete cnc router kit
    Attached Thumbnails Attached Thumbnails DIY Aluminum cnc router Frame-cnc-066-jpg   DIY Aluminum cnc router Frame-cnc-072-jpg   DIY Aluminum cnc router Frame-cnc-075-jpg   DIY Aluminum cnc router Frame-cnc-076-jpg
    Feb 2009
    How about a shot of it assembled, and better yet, running...
    May 2008
    will post vid's this week
    Attached Thumbnails Attached Thumbnails DIY Aluminum cnc router Frame-img00548-jpg   DIY Aluminum cnc router Frame-img00547-jpg   DIY Aluminum cnc router Frame-img00549-jpg   DIY Aluminum cnc router Frame-img00559-jpg
    DIY Aluminum cnc router Frame-img00601-jpg   DIY Aluminum cnc router Frame-img00653-jpg
    Feb 2005
    United Kingdom
    Bro they look amazing and well done on supplying the consumer with an affordable package well done! Ok so what will each machine's cutting capacity be ? bro would you ship to the UK? can't wait to get more info on these, you are onto a winner for sure and I think you have a customer right here, let us know ASAP Cheers!
  7. #7
    May 2008
    I am sending a full 30x48 complete asembled to London UK is $160 + 55 usd fowarder charge thats with ballscrew and z axis . 30X48 has 24X43 travel
  8. #8
    Feb 2005
    United Kingdom
    Thanks Gio for the lightning quick answerCHEERS! Ok so if I was to order the 20 X 36 frame what will the cutting capacity be and also what will be included in the kit? I see that there is no z axis on the machine is this available separately or does it come with the kit ? Basically all I want is the main machine frame with z axis and I can supply my own leadscrews and electronics is this doable and also how much ? Feel free to PM me or post here its up to you bro but I am very,very interested.
  9. #9
    Aug 2009
    gio666
    WOW !!!
    Post 3 picture 2... How much for the complete kit with motore and controller?
  10. #10
    May 2008
    20x36 is 14x31 cutting ,
  11. #11
    May 2008
    The Z axis is
    16mm rails
    16mm ballscrew and bearing house
    $200 for 5 inch travel
    $250 for 8 inch travel
    $290 for 10 inch travel
    Attached Thumbnails Attached Thumbnails DIY Aluminum cnc router Frame-img00656-jpg   DIY Aluminum cnc router Frame-img00657-jpg   DIY Aluminum cnc router Frame-img00659-jpg   DIY Aluminum cnc router Frame-cnc-077-jpg
  12. #12
    Feb 2005
    United Kingdom
    Damn just a tad too small, the length ie X is good but I need to cut width wise 16 inches, looks like the bigger machine will be what I will need. Ok so how much will the larger machine plus the Z axis be ? with the leadscrews and without ? Oh boy I am getting excited now also what is the wait time from payment to machine kit being sent ?
    Sorry for all the questions and answers but have to ask before I can commit hope you understand.
  13. #13
    May 2008
    ok, the 30 wide has 24 travel and can get X lenght 24 to 60 inch
  14. #14
    Oct 2009
    Quote Originally Posted by gio666 View Post
    What is cost of complete kit? What is included(i.e. Mechanical or electrical instructions? Support? Software?)
    It looks great, you have got my interest.
    Good Luck!
    Streamside
  15. #15
    May 2008
    I dont know if you would want the Z axis with out ballscrew, are ballnut housing and bearing house are in one inless you have same type of ballnut?
    Attached Thumbnails Attached Thumbnails DIY Aluminum cnc router Frame-img00660-jpg   DIY Aluminum cnc router Frame-img00661-jpg
  16. #16
    May 2008
    20" end frame
    15" Y uprights
    4 16mm bearings and ballnut housing
    4 20mm bearings and housing
    X 36" 2005 ballscrew with nut
    Y 20" 1605 ballscrew with nut
    20mm Ballnut Bracket
    2 couplings with nut
    2 Nema 23 Motor mount
    4 single Bearing house with 6200 w/ double sealed bearing
    6 mm bolts
    complete frame $870
    3 270 oz motors ,3 4.2a drivers, breakout board with cable $260 with full frame only ,same with 425 oz motors $280
    ONLY need 6mm hex wrench to assemble
    one year warranty on all parts including bearings ,ballscrews
  17. #17
    May 2008
    30" end frame
    17" Y uprights
    4 X 20mm bearings and housing
    4 Y 20mm bearing with ballnut housing
    X 1200mm 2005 ballscrew with nut
    Y 750mm 1605 ballscrew with nut
    6 mm bolts
    Complete $999
  18. #18
    Sep 2007
    australia
    wow it is impressive for the price
  19. #19
    May 2008
    40x60 Frame 1/2 Aluminum
    2 40" end frame
    17 1/2 " Y uprights
    2 60'" Aluminum profile
    1 40" Aluminum profile
    4 X 25mm bearings and housing
    2 60" X 25mm Linear rails
    2 40" Y 20mm Linear rails
    X 60" 2005 ballscrew with nut
    Y 40" 1605 ballscrew with nut
    6 mm bolts
    Complete $1,150
    40x72 $1.250
  20. #20
    Apr 2005
    Brazil
    Finally! An affordable, good sized and (judging by the pics) solid,
    well built, thick Alu machine!
    When can we see videos of the different size machines actually cutting?
    Will you ship internationally?
    Could you give us an idea of the shipping costs?
    Nelson
