Products
Results 1 to 4 of 4
Thread: Products
    Registered FunnyNYPD's Avatar
    Nov 2007
    Canada & USA
    Default Products
    July-13-2009
    Au Group Electronics is pleased to announce the release of Controller Area Network (CAN) simulator(s) for Fleet Management System (FMS).
    http://www.auelectronics.com/System-...mSimulator.htm
    http://www.auelectronics.com/forum/i...opic,24.0.html
    Current Truck FMS standard and Bus-FMS standard are widely adopted by European Truck and Bus OEMs, and it has also been accepted by some North American OEMs too, especially in the Mexico market.
    The Au FMS simulator are palm size CAN signal simulator which can generate all CAN parameters defined by Truck FMS standard and BUS FMS standard. It can be widely used as valuable tools for any situation from product-line test, incoming inspection, business demonstration, to product development and product validation.
    Major Hardware Features:
    * SAE J1939-15 Type II ECU, contains an internal 120 ohm load resistor for easy network setup
    * Common-Mode Choke and TVS (Transient Voltage Suppressor) protection on CAN bus
    * Compact size: 4-1/8" L X 1-3/4"W X 7/8"H
    * 9 LED indicators: POWER, RANGE, BTLD, UP+100%, DOWN+0%, 80%, 60%, 40%, 20%, Led will blink when one of these six numeric-specified control point is selected.
    * Enclosure color: Black or PC white
    * 1 Buzzer
    * 3 push buttons: MENU, DOWN, UP, the FMS CAN signal can be adjusted by push buttons
    * 1 RS232 interface for software update, license management and remote control (Plus editions only)
    * 1 DB9 male connector for Power, Ground, CAN_H and CAN_L
    * Accessory cables are available and must be ordered separately, both RS232 Serial Extension Cable (part #: CBL-RS232-01) and 4-wire CAN Cable for DB9 Male Connector (part #: CBL-CAN-01, which provides power supply and CAN network connection to the simulator) are available and must be ordered separately
    * Power supply: +9 ~ +12VDC, 250 mA max (+9 V recommended)
    * Operating temperature: -4 °F to 185 °F (-20 °C to 85 °C)
    Major Operating Features:
    * Ease of use - Easy-operate design with production-line-operator and sales person in mind
    * Smart features - Recall last operating mode at power-on, capable of generating dynamic data, etc.
    * STATIC MODE output steady FMS CAN signal, which can also be adjusted manually
    * DYNAMIC MODE automatically generate dynamic FMS CAN signal
    * STATIC MODE and DYNAMIC MODE can be easily alternated
    * PC remote software is available for all "Plus" editions, it can show simulated FMS signal on a computer screen
    * All Control functions are also available from the PC remote software for all "Plus" editions
    * Easy In-field license upgrade with Au license management tool. For owners with "Truck FMS" Edition(s) or "Bus FMS" Edition(s), when more function is needed, they can be easily upgrade to "Truck and Bus FMS" Edition(s)
    * In-field software code (firmware) update Capability for minor upgrades (Order #: SVS-SIM-FMS) with Au PIC Bootloader
    * Annual support and minor upgrade services (Order #: SVS-SIM-FMS) are available
    * Custom design and modification are available
    Truck/Bus FMS Simulator at working condition:
    Truck/Bus FMS Simulator connect to a laptop:
    Truck/Bus FMS Simulator connect to a typical FMS CAN network
    Six editions of CAN bus signal simulation device has been released by Au Group Electronics:
    1. Truck FMS Edition (He)
    2. Bus FMS Edition (Ne)
    3. Truck and Bus FMS Edition (Ar)
    4. Truck FMS Plus Edition (Kr)
    5. Bus FMS Plus Edition (Xe)
    6. Truck and Bus FMS Plus Edition (Rn)
    The Plus Edition = "non-Plus Edition" + PC remote terminal
    All "non-plus" editions can be upgraded to "Plus" editions.
    "Truck FMS", "Bus FMS" can be upgraded to "Truck and Bus" FMS editions.
    PC Remote Terminal for "Truck and Bus Plus Edition":
    Truck FMS remote terminal:
    Bus FMS remote terminal:
    Nov 2007
    Canada & USA
    Now all Truck / Bus FMS simulator are available at our on line store:
    http://www.auelectronics.com/product...m/sim-fms.html
    Nov 2007
    Canada & USA
    Default Why buy FMS Simulator from Au Group Electronics?
    There are a few FMS (Fleet Management System) related simulation device on the market, after looking around at our competitors products, here are a few reasons why buy FMS CAN signal simulation devices from Au Group Electronics:
    1. To get the FMS CAN signal from Au FMS Simulator,no PC / PC software is required, which means no headache on PC crashing, software installation, and software configuration
    2. Turn-key solution from a single supplier. End user don't have to buy the hardware from supplier A, then buy additional software package from supplier B. And this single supplier approach eliminates the headache of talking to supplier A for hardware setups, talking to supplier B for software configurations. When issues were found related to both supplier A and B, neither can provide a workable solution.
    3. Technology advantage on CAN bus signal simulation from Au Group Electronics will secure user don't have to wait a long time to get the new FMS data which may be released in the near future. One example is: the Bus FMS Ver. 00.02 was officially released on July-07-2009, Au BU-FMS simulator covers all new data on this releases were available on July-13-2009, which is only 3 business days after the new standard was published.
    4. To use Au FMS simulator, no CAN bus experience is required. All Au FMS simulator are designed as a "Plug and Play" device.
    5. Multiple devices are developed and available for different customer need. Low cost solutions are available for users who only need the Truck FMS or only need the BUS FMS CAN signals.
    Nov 2007
    Canada & USA
    Default Now the promotion price is available for FMS Simulators.
Products
Products
Products
