Feature of new design big size water jet cutter EK2060:
Specification of big size 2000*6000mm waterjet cutting machine EK2060:
1 EAAK New design big size water jet cutting machine with large cutting size up to 2000*6000mm or 2000*8000mm.We can also customize 3000*10000mm refer to customer request. 2 This series of machine specially equips enhanced structure and upgraded transmission system,more suit for cutting heavy thick metal plate and stone plate.
Model EK2060 X Y axis Working size 2000mm*6000mm Z working height 150mm Cutting Pressure 420Mpa 37kw UHP pump Control accuracy 0.01mm Cutting accuracy 0.1-0.2mm Repositioning Accuracy 0.05mm Max cutting thickness 300mm(depends on materials) Max. moving speed 6000mm/min Power supply 380V 50Hz Environmental temperature -10-50°C Max flow rate 3.7L/min Max oil discharge 206L/min Max delivery capacity of oil pump 106L/min Control system Ncstudio IPC control system CAD/CAM software AutoCAD,ArtCAM Drive motor Japan Yaskawa servo drive motor
- Waterjet cutting machine promotion of JETE WATERJET
- Sell waterjet cutting machine, CNC five-axis dynamic water jet cutting machine
- New Machine Build- Sell waterjet cutting machine, CNC five-axis dynamic water jet cutting machine
- Just IN- Sell waterjet cutting machine, CNC five-axis dynamic water jet cutting machine
Shandong EAAK Machinery Co., Ltd www.sinowaterjet.com
Email: Jack@sinowaterjet.com Whatsapp:0086 130 2657 0308
