EDM Wire Cutting Machine Electrical Discharge Machining
Results 1 to 1 of 1
Thread: EDM Wire Cutting Machine Electrical Discharge Machining
    Default EDM Wire Cutting Machine Electrical Discharge Machining
    Product Link:
    https://www.automationtechnologiesin...arge-machining
    Contact us for more details, let us know if you need larger worktable size!
    (949)690-9095 / automationtechinc@yahoo.com
    Worktable size (LxW): 340×560 mm
    CNC axis travel(X×Y) : 300×360 mm
    Max. cutting workpiece thickness: 400mm
    Max cutting taper: 6°/80mm
    Max workpiece weight : 200kg
    Wire electrode diameter: 0.18mm
    Position accuracy: 0.02mm (GB7926-2005)
    Processing accuracy (cutting eight prism): 0.015mm (GB7926-2005)
    The working liquid volume: 50L
    The best roughness of the processing surface(several cutting): Ra2.3um
    Max cutting efficiency: 100mm² /min
    Power consumption AC380V/220V 50Hz
    The X, Y, U and V axes are driven by the stepping motor. The machine control cabinet of electric and programming control system has the high-performance pulsed power supply and 15inch LCD (liquid-crystal display).
    The program system is Autocut programming control software.
    Machine Introduction:
    1. Single cut
    2. Common steel guide
    3. The small water tank without paper Filter
    Item & Qty Include:
    Main machine 1
    Control cabinet 1
    Working liquid box 1
    Worktable water retaining cover 1
    Machine sizing block 1
    Cranker/crank 1
    Processing specimen 1
    Vertical corrector 1
    Workpiece frame and simple clamp 1
    Molybdenum wire installation device 1
    Wheel loading and unloading tool 1
    Technical documents:
    instructions, certificate of compliance, packing list and programming operation manual
    One Year Warranty
    Attached Thumbnails Attached Thumbnails EDM Wire Cutting Machine Electrical Discharge Machining-edm-machine1-jpg   EDM Wire Cutting Machine Electrical Discharge Machining-workpiece1-jpg
