Product Link:
https://www.automationtechnologiesin...ngraver-router
1: New USA made Taig 2019CR-ER Cnc Mill (This is the bigger taig mill)
1 year warranty on mill and electronics, no return accept
This includes 6 ER16 collets ( 1/16, 1/8, 3/16, 1/4, 5/16, 3/8 ) a Vise, and 2 End mills (1/8 & 3/16 inch) .
The Knob on the shaft (on the picture) is not included any more
This is a very robust and heavy machine 110 pounds of shipping weight
2: The controller features a 10 microstepping Gecko g540 stepper driver running at 48volts, 7.3A
Why is 48volts volts so important? Faster rapids and more power
Why is microstepping so important? Real smooth cuts
- Mid-band resonance compensation
- Auto standby current (70% current)
- Short-circuit protected
- Optoisolation on all LPT signal pins
- Two 1A at 0 to 50VDC rated outputs
- Four SPST to GND inputs (TTL)
- TRIM adjust for motor smoothness
- Easy to service, removable drives
- 10kHz watchdog timer (charge pump)
Stepper motors feature:
Low inductance: NEMA 270oz bipolar stepper motors for x, y, z
They produce quick rapids for faster production time
The bottom of the slot is ½ the opening or top of the slot is 1/4
X travel 12 inch
Y travel 5.5 inch
Z travel 6 inch
Spindle Motor  ¼ hp 1100-11,000 rpm
Continuous duty for all day operation 120volt
Double shaft Stepper X, Y, Z axes 270 oz in
Table size 3.5 x 18.5
