Are you cutting plastics on a Dim saw or Angle plant?
Hi All if you are cutting plastics, up to and including medical grade on a dim bench or and able plant, or even a cnc machine, would you like the tool life to be increased? Would you like the quality of cut to remain for weeks rather than days? We have the perfect tooling solution for you! PCD circular saw blades now have the geometry and tip design to achieve this. Save money and generate extra machine time by cutting out those expensive tool changes! Install PCD cutting blades on your machines. Contact Arrow Diamond Tooling LTD on 07979253263 or email us arrowtooling@icloud.com Thank you for viewing.
