Feature: The structure design of the whole set of equipment is reasonable,compact and beautiful in appearance; the world's advanced and mature technology and configuration system are adopted to ensure the equipment has good and stable accuracy. It has very high stability and is suitable for continuous production and processing.
Specification of eaak desktop waterjet cutter Model EK6060 X Y axis Working size 600mm*600mm Z working height 150mm Max Pressure 420Mpa 37kw UHP pump Control accuracy 0.01mm Cutting accuracy 0.1-0.2mm CAD/CAM software AutoCAD,ArtCAM Repositioning Accuracy 0.05mm Max cutting thickness 100mm(depends on materials) Max. moving speed 5000mm/min Power supply 380V 50Hz Environmental temperature -10-50°C Control system Ncstudio (Shanghai) software IPC controller Drive motor Japan Yaskawa servo drive motor
- Newest CNC waterjet cutter for cutting glass metal stone with thickness 100mm EAAK
- New Product- EAAK water jet cutting machine EK3020 for glass marble cutting
- New Product- water jet glass cutting machine-sinowaterjet
- Just IN- Water jet cutting machine for cutting glass stone metal
- Just IN- Special water jet glass cutting machine SN2030R
Shandong EAAK Machinery Co., Ltd www.sinowaterjet.com
Email: Jack@sinowaterjet.com Whatsapp:0086 130 2657 0308
