Mahoney brand of Simplified Tools brings to market the novel CO2 Laser Beam Visualization Tool
The beam alignment visualization tool can easily pay for itself with just one or several uses.?
CLICK TO VISIT STORE FOR PURCHASING THE VISUALIZATION TOOL.?
Examples include:
(1) Visual spot check for the laser work table prior to running a laser job--to determine that the laser is aligned as needed for the material size to be lasered.
(2) Fast correction for laser misalignment that causes not-straight cuts.
(3) Fast correction for laser misalignment that causes laser engraving depth and quality to vary over the material.
(4) Speedier laser beam alignment to ensure the laser machine is operating correctly.
(5) Saving costly material losses by enabling frequent, fast laser beam alignment
(6) Performing a full laser beam alignment without causing the risk of soot or sticky fumes floating onto expensive mirrors and optics.
(7) Speedily adjusting laser tube alignment to match gantry alignment after standard beam alignment failed to produce adequate results. In other words, rather than forgoing this alignment procedure because it took too much time using antiquated methods, laser operators get the full and complete beam alignment done to its maximum accuracy for their laser engraver/cutter machine because they do not quit early but see the alignment task through to completion.
The visualization tool shows the raw CO2 laser beam for CO2 lasers (8-11 microns) with at least 40 watts of power available illuminate the tool. Works for laser machines including CO2 lasers engravers and cutters with mirror mounts manufactured in China. Laser machines include GW Weike, and others.
Each visualization tool is fully tested, aligned, and each tool has an engraved serial number.
Comes with instructions and convenient storage container.
OPTIONAL: Add camera viewing to enable your laptop/PC to show an enlarged live view of the CO2 laser beam displayed with cross-hairs. The camera permits more convenient viewing as the laser operator's computer can be positioned to view while simultaneously adjusting mirror mount alignment, then jogging the gantry/focus assembly then further adjusting--all while the CO2 laser remains on with a visual beam for alignment calibration.
ONE YEAR FULL WARRANTY FOR MANUFACTURER DEFECTS.
