As for mechanics
X, Y, Z working area: 600 (Y) * 390 (X) * 120 (Z) mm
External Dimension: 865 * 680 * 570mm (L * W * H)
6063/6061 aluminum alloy structure
X axis in 1605 ball screws
Y axis in 1605 ball screws
Ball screws Z axis 1204
57 two-phase motors 3A 150N.cm x y z
the 4th axis mounts a 57 1.5A motor
1500w water cooled spindle
Since I don't understand much of electronics I would need advice on what to buy I saw a stepperonline kit
https://www.omc-stepperonline.com/it...ionamento.html
besides this kit I would like to take an inverter and board board parallel port use mach3.
Usually wood work I would also like to do a little something on aluminum I have a budget 350 euros I would like to take power supply motors and drivers on that site and if the inverter case and parallel board board somewhere else.
Could you give me some advice how to coordinate everything considering also the mechanics I have.
I wanted to take everything there but the seller told me that with that inverter kit and board they were not going well.
I would like to take everything on that site I have difficulty coordinating everything.
Thanks in advance to those who can help me.
