2030 cnc wood router machine new arrival woodworking cutting machine with high efficiency
Cost effective price and professional suggestions for you, Contact us now by whatsapp +86 15064026772, email
manager@elephant-cnc.com
# 2000x3000x400mm effective working area;
# Italian HSD 6.0KW Air Cooling spindle with 7.5KW DELTA inverter;
# DSP A11 handle controller with USB port;
# Stepper motor FL118 and YAKO2811 bigger driver;
# Helical rack gear for X, Y axis, Taiwan TBI ball screw for Z travel;
# Taiwan PMI linear guide and rails, 20#;
# T-slot and Vacuum working table;
# Japan OMRON limit switch for X, Y, Z axis
# Highly flexible towline, fire-resistant double-sheathed cable, Shanghai Cardiff brand;
# Auto Lubrication system
# Artcam 2012 software for free
# Working voltage: 380V/50HZ/3PH
# Welded Machine Structure, heavy duty machine bed;
# 7.5KW Water Circulation Vacuum Pump
# 3.0KW double bags dust collector;
# Auto Oil Mist Sprayer;
# Plywood packing;
# Standard Accessories;
- Just In 1530 atc woodworking cnc machine for carving and cutting from customer feedback
- Just In Blue Elephant Customer Feedback Top Quality 2030 CNC Router Machine For Aluminum Wood
- Just IN- Latest design Higher configuration precision 2030 wood carving cnc router machine wit
- High Efficiency CNC Wood Router Speed Up Your Business
To be first brand CNC Manufacturer & Wholesaler platform.
--------Jinan Blue Elephant CNC Machinery Co., Ltd--------
