2019 best CNC router machine with standard carbide bits is easy to cut aluminum panels, aluminum parts, aluminum sheets and aluminum plates. Aluminum requires hardier CNC router bits unlike wood since fragile bits will break easily when used on aluminum. CNC router bits also tend to dull off quite fast when used on aluminum.
You can cut the following projects with a CNC router:
Carving and Contouring: Aluminum makes a perfect carving material using a CNC router.
Sign Letter fabrication: Aluminum is one of the best materials to use in making sign letters.
Musical instruments: With the use of CNC router, aluminum is used in making customized parts of musical instruments.
Making instruments: With the use of a CNC router you can make some instruments using aluminum. These include cups, trophies, and other aluminum accessories.
Exhibits and samples: Using a CNC router, aluminum materials are used to make exhibits and samples that are used in trade shows and exhibitions.
Safety rules to follow when cutting aluminum with a CNC router:
It is wise never to take chances in terms of your safety when cutting aluminum since even tiny chips of aluminum can cause serious injuries. With wood protection is mandatory but it is riskier to handle aluminum with the lack of proper protective gear.
User manual: You should follow the manufacturer’s guide on the aluminum cutting bits to be used.
Protective gear: Eye, ear, and hand protection are mandatory when routing aluminum. You should get gloves, long sleeved shirts, and get a full face shield.
Better slow and sure: Never be in a hurry when routing aluminum using a wood router. Be relaxed and don not push the machine. Use a variable speed router since it is much easier to keep things in control.
Lubricant and coolant: You should have a lubricant and lots of coolant when working on aluminum so and to minimize the friction and cool down the heat generated.
If you have an idea to get the best CNC router for aluminum, check out from:
The Best CNC Router Manufacturer
STYLECNC is a guaranteed manufacturer for CNC Router, Laser Cutter, Laser Marker, Laser Engraver, Wood Lathe and Plasma Cutter. Official website: https://www.stylecnc.com/
