New Product EAAK water jet cutting machine EK3020 for glass marble cutting
Results 1 to 1 of 1
Thread: EAAK water jet cutting machine EK3020 for glass marble cutting
    Member sinowaterjet's Avatar
    Jul 2014
    China
    Thumbs up EAAK water jet cutting machine EK3020 for glass marble cutting
    Product description:
    Water jet cutting machine is kind of using high pressure water cutting machine, belong to the category of could cutting, has the avantage such as compact structure, no sparc and not produce thermal deformation or heat effect. A high pressure waterjet cutting machine is a tool used for slicing metal and other materials using a jet of water at high velocity and pressure. Featuring a low noise, no pollution, high precision and high reliability, our water jet cutting machine has been used in a variety of applications, including mining, automobile manufacturing, paper manufacturing, food, art and architecture. Water jet machines can be used to cut rubber, foam, plastic, composite, stone, tile, marble, glass and other materials.
    Features:
    • 50 HP High 420 MPa pressure for smooth finish cutting at high speed.
    • Main heart of Supercharger, "Intensifier" is "Made in USA".
    • User friendly & minimum maintenance cutting head design with USA make "Water Switch Seal Kit" & other parts.
    • All parts of machine are processed on Highly accurate YASKAWA servo motor (made in Japan). Which gives you trouble free operation & long life of parts.
    • Use special water cutting machine software, a day to achieve a comprehensive grasp
    •Non-standardized model design customization?Customizable submersible adjustable water level platform, equipment working noise is lower than 75Db.
    Contact:
    EAAK Water jet Cutting Machine
    jack@sinowaterjet.com
    Attached Thumbnails Attached Thumbnails EAAK water jet cutting machine EK3020 for glass marble cutting-eaak-waterjet-cutter-3020-small-jpg
