UniRobotics SA now stock the Stand Alone PLC Controllers (3 axis, 4 axis, 5 axis and 6 axis)
4-Axis PLC controller 500KHz Stand Alone CNC Motion Controller
This PLC Controller is a 4-axis, motion controller which is extremely easy to use The control period of each position is 4 milliseconds, with high control precision! The highest uniaxial output pulse is 500 KHz and the pulse width can be adjusted. Supports common stepper motor and servo motor.
The numerical control system adopts the ARM + FPGA design framework. The arm can terminate the part of the human-computer interface and the code analysis and the FPGA can complete the part of the algorithm and control the generated pulse, with a reasonable design, reliable control and easy operation.
The design structure of the RMHV2.1 panel Is it rational? The CNC motion system controller can only be terminated with 17 keys and is compatible with FANUC with high universality to be compatible with the G code set.
This manual introduces the operating method of RMHV2.1 , the machine tool and the operating procedure of the machine tool. For a large amount of graphic representation and examples, the applications can quickly learn to use the RMHV2.1 CNC system
Performance parameter of the card:
- Normal digital input interface for coupling isolation of 16 circuits and couplers
- Normal digital input interface of 3-circuit optocoupler coupling isolation
- Output interface of the spindle control port 0-10 V with analog quantity (can be modified as PWM output);
- Supports 4-axis stepper motor control, the highest single-axis control pulse output is 500KHz;
- The main control equipment is an energy input of 18 V-32 V, the current capacity should not be less than A;
- It supports the USB flash disk to read the G code, and the size of the G code file has no requirement;
- Equipped with MPG port and MPG digital display support, as well as with the general MPG on the market.
- Supports panel key with single-axis manual operation, manual step and contact;
- Admits the operation of quickly specifying the operating position;
- Supports multi-coordinated systems (with automatic saving function in case of power failure);
- Supports the function of saving data automatically after shutting down (press the start to automatically save the data in the operation, automatically save the data after turning off)
These controllers can now be purchased via our online store:
