1000w Fiber CNC Laser Cutting Machine Price for Stainless steel 6mm Made in China
ACCURL Manufacturers 1000w Fiber CNC Laser Cutting Machine team now introduces its newest generation in tube and profile processing technology-the fiber laser tube cutting system. Technological nnovation has brought us the Smart KJG Series. With exceptional reliability and high beam quality, our fiber laser cutting machines continue to be leaders amongst the competition.
General Features for 1000w Laser Cutting Machine:
1. %70 low electricity consumption in comparison with CO2 Laser
2. Up to %300 faster cutting
3. High wall plug efficiency (>%30)
4. Flexible beam path
5. Maintenance free
6. Copper, brass cutting ability
7. High output power
8. High optical quality
9. Compact size
10. Reliability
Standard Equipments for 1000w Laser Cutting Machine:
1. IPG YLS-1000W Ytterbium Laser Resonator
2. Linear Driven X, U and Y Axes
3. High Rigid Frame
4. Empower or FAGOR CNC Controller
5. Precitec Cutting Head
6. Lantek Software
7. Shuttle Table
8. Chiller Unit
9. Proportional Gas and Piping System
10. Dust Filter
11. Compressor
12. Conveyor for Scraps
Chief Details for 1000W Laser Cutting Machines:
Specification for 1000W Laser Cutting Machines:
Laser power 1000W IPG Fiber Laser Laser source Germany IPG fiber laser resonator Processing surface (L × W) 3000mm x 1500mm CNC control Shanghai FISCUT CypCut Laser head Switzerland Raytools Power supply AC380V±5% 50/60Hz (3 phase) Total electric power 14KW Position accuracy X, Y and Z axle +0.03mm Repeat position accuracy X, Y and Z axle +0.02mm Maximum position speed of X and Y axle 72m/min Acceleration 1g Max load of working table 1000kg Drawing programming mode AI, DWG, PLT, DXF format import directly Machine weight 5T *** Note: As products are constantly updated, please contact us for latest specifications. ***
Cutting Thickness Limit for 1000W Laser Cutting Machines:
Material Cutting Thickness Limit Carbon steel 12mm Stainless steel 6mm Aluminum 4mm Brass 3mm Copper 3mm
Main Parts for 1000w Laser Cutting Machine:
Article Name Remark Fiber laser resonator IPG (Germany)/1000W Servo motor and driver DELTA (Taiwan) Ball screw rod HIWIN (Taiwan) Liner guide HIWIN (Taiwan) Gear rack YYC (Taiwan) Laser head RAYTOOLS (Switzerland) Chiller TONG FEI (China) Controller FISCUT (China) Gas Proportional valve SMC (Japan) Reduction gear box APEX (Taiwan)
website:China CNC Machine Manufacturer - ACCURL
