ACCURL®MAX-T Series punch press offers an O-frame and is characterized by rigidity and high geometric precision. It features a capacity of 30 metric tons and is able to work in mild steel thicknesses up to 6.5 mm.
Advanced Hydraulic System:
1. The well engineered mechanical parts in the H+L Hydraulic ram are manufactured according to high precision standards. The HS3 electronic stoke control is controlling the speed and stroke of the 50 tons hydraulic punching head.
2. Uniquely designed Machine structure ensures less preventive maintenance.
Turret Structure with Multi Tools:
1. The auto indexable stations have a dual lead worm structure. the worms are custom machined in pairs and are highly accurate. the worm gear’s side clearance can be controlled under 0.001mm and can be adjusted for wear.
2. The turret comes with 4 main layouts from 32 stations to 52 and up to 4 auto indexing stations.
3. Permanently engaged auto index drive system reduces errors and avoids downtime.
4. Each station can be fitted with various brand tools, such as Mate and Wilson.
32 Stations 2 Auto index:
ACCURL entry level turret offers a full set of tooling with two auto indexing stations.
32 Stations 3 Auto index:
With one flex station,the 32 station turret can be upgraded with an additional auto index D station.
42 Stations 4 Auto index:
ACCURL most flexible design comes with four auto indexing stations to offer the most advanced material processing capabilities.
CE-Approved:
When designing the T-series, the safety aspect has been specifically taken care of. This is done by means of a CE-approved optical detection-system that is placed around the machine working area.
Standard Equipments:
1. FANUC Series Oi-PO CNC Control System
2. Automatic repositioning clamps and loading switches.
3. Tool lubricating system (Airblow).
4. Free standing control panel.
5. Control with foot pedal.
6. 1 software (Lantek or RADAN software).
7. User manual and maintenance catalogue.
8. 15 x A station 1/2’’ fixed 1,6-12,7 mm round
9. 12 x B station 1-1/4’’ fixed 12,8-31,7 mm round
10. 2 x C station 2’’ fixed 31,8-50,8 mm round
11. 1 x D station 3-1/2’’ fixed 50,9-88,9 mm round
12. 3 x D station 3-1/2’’ index 50,9-88,9 mm round
13. Digital oil temperature indicator.
14. Software for using wheel and forming tools.
15. Scrap box.
16. Chain protection around the machine (safety system).
17. Hydraulic oil cooling system.
Optional Equipments:
1. Notching and forming tools for various dimensions and forms.
2. Light barrier (CE standard machines).
3. Additional sheet holding clamps.
4. Multi tools of 3,6,8 stations.
5. Adaptors for various stations (B, C, D).
6. Special coated tools for notching stainless materials (TIN, TICN, TICN Plus, MOVIC).
7. Work chute.
8. Stainless steel table with ball bearing support.
