Garment Industry Machine-Laser Cutting Machine-Auto Feeding-G.Weike Laser-Abby!
Hi Everyone,
Someone who is doing Garment,Leather,Plush Toys, and Computer Embroidery,maybe you will get many profits from this Auto Feeding Laser Cutting Machine!
This machine is especially designed for Garment Industry.it can do accurate cutting on different kinds of on various textile fabrics in random figure. Adopt in size crawler working table and negative pressure absorb conveyer, so it can ensure the smooth of the material when cutting.Working in with feeding system,it can meet the requirement for continuous and automatic batch cutting.
Aplicable range:This model is suitable for different kinds of textile, especially Seamless bonding fabric;
Designed for garment industry.
Specification:
Laser Power: 80W RECI Tube(Bigger Power Tubes are optional.)
Working area: 1600mm×2500mm
Cutting speed: 0-36000mm/m
Work platform: rawler type work platform
Working speed: Adjustable
position accuracy: ±0.1mm
Control system: DSP DSP control system in USB mode
Cooling mode: constant temperature water-cooling
Working voltage: AC220V±5% / 50HZ
Graphic format supported: AI、BMP、PLT、DXF、DST
Operating temperature:0°C-40°C
Operating humidity:5-95%
Gross power:<2000W
Whole machine size:4350x2560x1200mm
Weight:800KG
