we've opened English forum
Mach3 motion controller PLCM-E3
Interface: STEP/DIR/ENABLE
Max. freq: 100KHz
Pins: 3 ports (same to standard LPT ports), 36 "out" and 15 "in". All ins and outs are buffered.
Website: http://plmotion.com
User manual: http://purelogic.ru/doc/PDF/Controll...sh/plcm-e3.zip
Contact: av@purelogic.ru
Main features:
- Ethernet(using TCP/IP) or USB Full-speed connection
- Up to 6 axis, 100kHz pulsing engine
- PWM spindle control
- Probing
- Torch Height Control
- Slave Axis support
- Soft limits
- Easy firmware update
- DB25F connector to reproduce standard LPT connection
- DLL for direct access to controller could be provided
- Power supply 5Vdc or USB
- Just IN- Ethernet(Lan) Connection, Motion Controller for Mach3, CM126-ESS
- Purelogic Ethernet motion controller PLCM-E3 Wiring / Mach 3 / Super PID
- Just IN- Cnc, Ethernet Connection Motion Controller for Mach3, CM116-ESS
- Purelogic USB tiny Mach3 motion controller PLCM-LPT2
- Just IN- Ethernet Connection, Motion Controller, Mach3, New !!
Purelogic RnD
Purelogic RnD
Our controllers on the eBay:
CNC Mach3 motion controller Purelogic PLCM-E3p, USB / Ethernet, 6 Axis, PoE
Purelogic RnD
Does your control support Mach3 backlash compensation?
Yes, backlash support implemented in plcm
Purelogic RnD
Purelogic RnD participated in the "Metalloobrabotka-2012" Exhibition (Moscow)
On this fair(one of the biggest in Eastern Europe) we've introduced our new devices:
CNC pendant PLCM-R1 with Ethernet support for Mach3.
new breakout board PLC4x-G2
milling machine PLRA1-RG
and other products
Purelogic RnD
Engraving and milling with PLCM-E3.
All machines are connected by Ethernet
Purelogic RnD
Since July, 2012 customers from United Kingdom can buy PLCM controllers in Zapp Automation online store.
Purelogic RnD
Alexey Vorobyev,
This BOB for stepper only, not for servo?
This is not a BOB, this is a motion controller. It generates STEP/DIR/ENABLE on out pins, so can be used with stepper or servodrives(STEP/DIR compatible, for example Purelogic servodrive PLD2080s). It can be connected to drives directly, but it's highly recommended to use a BOB like Purelogic PLC4x or PLC4x-G2.
Purelogic RnD
Yes, backlash support are implemented in PLCM.
Functions of Mach are not supported listed below:
1) Feedback through external encoders;
2) Movement using MPG ports;
3) Spindle control through Step/Dir
4) Kinds of lathe work that requires synchronization with spindle
Purelogic RnD
When can I buy PLD57 Stepper Driver or other parts in Germany or on eBay etc.
We have no distributor in Germany at the moment, but you can send us an inquiry to info@purelogic.ru. We can arrange delivery by DHL.
If you wouldn't install driver on motor case, i recommend to use the PLD545-G3 driver, its' fucntionality is better a little bit.
Purelogic RnD
Our customer shared video with plasma cutting using PLCM:
"http://www.youtube.com/watch?v=tAzWFGxnh8g"]THC - YouTube
Purelogic RnD
It's also possible. But max pulsing freq. is 100kHz, so if you use 2500-point encoder, maximum speed you can get is 10 rps(600 rpm).
In most cases to get good speed you should use servodrive's internal pulse mutiplier or encoder with 500 or 1000 points per turn.
PLs note, PLCM does not process encoders' signals.
Purelogic RnD
Hi
where i can get plugin for Mach3 ( Ethernet )
thanks
Maybe here:
https://purelogic.ru/
UCCNC 2017 Screenset
Hi Ger
thanks for fast reply but
its not there for sure
I tray to find it
on manual they have link to plugin but nothing there
https://purelogic.ru/files/downloads/SOFT/PLCM.zip
i contact them but its weekend
probably will have answer tomorrow
jasko
