myCNC - CNC control software - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 29 of 29
Thread: myCNC - CNC control software
  1. #25
    Dec 2010
    Quote Originally Posted by rexcobey View Post
    1. how to changed the language to English
    to change language-
    1.select Settings tab widget
    2. select system settings
    3. choose the last section to open it (preferences)
    4. choose the last item (language selection)
    5. In new dialog select the language
    6. Press OK
    7. Press save button and restart myCNC software
    Attached Thumbnails Attached Thumbnails myCNC - CNC control software-mycnc-1-78-02-03-lang-jpg   myCNC - CNC control software-mycnc-1-78-02-01-lang-jpg
    http://www.pv-automation.com - myCNC control & software.
  2. #26
    Dec 2010
    Also your THC are suitable to use in acetylene fuel torch or not? because right now i am using acetylene fuel and maybe in future i will use also plasma.
    No, myTHC board measures Plasma arc voltage and uses this siganl as feedback to keep stable torch height.
    For gas cutting you need capacitory sensor. We have this sensors for our previous generation cnc systems. At the moment myCNC doesn't support capacitory sensors.
  3. #27
    Dec 2010
    2. i cannot find the start bottom to start cutting.
    See attached screenshot
    my question is can i used my existing stepper drive and stepper motor to your to your Ethernet CNC controller myCNC-ET1.
    yes, no problem.
    myCNC controls have PULSE-DIR outputs and compatible with any stepper/servo drivers, that accept this signals.
    Pulse width is flexibly configured.
    Attached Thumbnails Attached Thumbnails myCNC - CNC control software-mycnc-1-78-02-08-operate-jpg
  4. #28
    Aug 2009
    Taiwan
    I am new learning cnc. I will download and try it.
    power chuck and collet chuck
  5. #29
    Dec 2010
    Raspberry Pi (Linux Embedded) port of myCNC control software is under developing.
    We've got preliminary version of myCNC working under Raspberry Pi (ARM based credit sized computer).
    On photos - working set ( myCNC-ET1 control board, Raspverry Pi computer, keyboard and monitor)
    Attached Thumbnails Attached Thumbnails myCNC - CNC control software-raspberry-et1-03-1024-jpg   myCNC - CNC control software-raspberry-et1-02-1024-jpg
