Shopbot Desktop MAX ATC CNC Router 1.1kW Spindle Vacuum Table Dust Boot FREE DELIVERY
Results 1 to 1 of 1
Thread: Shopbot Desktop MAX ATC CNC Router 1.1kW Spindle Vacuum Table Dust Boot FREE DELIVERY
    SteveD718's Avatar
    Jul 2022
    Default Shopbot Desktop MAX ATC CNC Router 1.1kW Spindle Vacuum Table Dust Boot FREE DELIVERY
    Accepting Offers. Will negotiate but lowballs will not get a response.
    I WILL PERSONALLY DELIVER THIS MACHINE TO ANYWHERE ON THE EAST COAST OR CLOSE TO IT. NO WORRIES ABOUT DAMAGE DURING SHIPPING. I WILL ALSO HELP YOU SET IT UP BEFORE LEAVING IF YOU WISH.
    This is a 6 month old Shopbot Desktop Max ATC CNC Router with Vacuum Table.
    It's been used for about 100 hours. I've upgraded to a larger size.
    I'll toss in 15 sheets of 1/4" Colorcore HDPE of various colors, 20 of 1/8 and 1/4" acrylic and 20 x 1/2 sheets of 1/2" Baltic Birch Plywood (about 30" x 60" each)
    24" x 36" x 5" cut area.
    Teknomotor Spindle + 6 x ISO20 tool holders.
    Vacuube + Vacuum Table. No clamps or other hold downs required for medium to large parts.
    6 position automatic tool changer with 6 x 1/4" collets and 1 x 3/8" collet.
    Dust boot + 20' 2 1/2 heavy duty groundable hose with 4" adapter on the end for use with your dust collector.
    I will also include 1 brand new Amana 1/4 compression bit and 1 brand new Amana 3/8 compression bit.
    Pickup is in Jacksonville, NC.
    I will also include the following bits. ALL BRAND NEW AND NEVER USED.
    - 51411?K Solid Carbide CNC Spektra™ Extreme Tool Life Coated Spiral 'O' Flute, Plastic Cutting 1/8 Dia x 1/2 x 1/4 Shank Up?Cut
    - 51769 Solid Carbide CNC Spiral Double 'O' Flute, Plastic Cutting 1/4 Dia x 1 x 1/4 Shank x 2?1/2 Inch Long Up?Cut
    - 46376?K Solid Carbide Spektra™ Extreme Tool Life Coated Up?Cut Ball Nose Spiral 1/4 Dia x 1 Inch x 1/4 Shank
    - 46170?K CNC Solid Carbide Spektra™ Extreme Tool Life Coated Compression Spiral 1/4 Dia x 7/8 x 1/4 Inch Shank
    - 46202?K Solid Carbide Spektra™ Extreme Tool Life Coated Spiral Plunge 1/4 Dia x 3/4 x 1/4 Inch Shank Down Cut
    - 46100?K Solid Carbide Spektra™ Extreme Tool Life Coated Spiral Plunge 1/8 Dia x 1/2 x 1/4 Inch Shank Up?Cut
    - 46200?K Solid Carbide Spektra™ Extreme Tool Life Coated Spiral Plunge 1/8 Dia x 1/2 x 1/4 Inch Shank Down Cut
    - 46009 Solid Carbide Spiral Plunge 1/16 Dia x 1/2 x 1/4 Shank x 2 Inch Long Up?Cut
    - 46385 Solid Carbide Up?Cut Spiral Ball Nose 1/16 Radius x 1/8 Dia x 1/2 x 1/4 Shank x 3 Inch Long x 2 Flute
    - 46381 Solid Carbide Up?Cut Spiral Ball Nose 3/16 Radius x 3/8 Dia x 1?1/8 x 3/8 Shank x 3 Inch Long x 2 Flute
    - 46171?K CNC Solid Carbide Spektra™ Extreme Tool Life Coated Compression Spiral 3/8 Dia x 7/8 x 3/8 Inch Shank
    - 46172?K CNC Solid Carbide Spektra™ Extreme Tool Life Coated Compression Spiral 3/8 Dia x 1?1/4 Inch x 3/8 Shank
    - 51404?K Solid Carbide CNC Spektra™ Extreme Tool Life Coated Spiral 'O' Flute, Plastic Cutting 1/4 Dia x 3/4 x 1/4 Inch Shank Up?Cut 45780 Solid Carbide V Groove Engraving 15 Deg x 3/16 Dia x 1/2 x 1/4 Inch Shank
    - 45705 Carbide Tipped V?Groove 60 Deg x 1/2 Dia x 7/16 x 1/4 Inch Shank
    45981 Carbide Tipped Bowl & Tray 1/8 Radius x 1/2 Dia x 1/2 x 1/4 Inch Shank
    Attached Thumbnails Attached Thumbnails Shopbot Desktop MAX ATC CNC Router 1.1kW Spindle Vacuum Table Dust Boot FREE DELIVERY-292230509_568128641384553_791356093435880419_n-jpg   Shopbot Desktop MAX ATC CNC Router 1.1kW Spindle Vacuum Table Dust Boot FREE DELIVERY-293418624_636538377317212_2681530315111222170_n-jpg   Shopbot Desktop MAX ATC CNC Router 1.1kW Spindle Vacuum Table Dust Boot FREE DELIVERY-292762173_1404433033387075_7648657817181996695_n-1-jpg
