- Selling our 2012 Mecanumeric MecaPro 3020 CNC for wood-alu-fabrics cutting
Posting here a selling ad for my CNC milling machine for wood/plastics/aluminium and extra head with knife modules. The machine location is Estonia, Tallinn. Machine is running on ballscrews in each axis - so it has high stiffness and cutting quality, even on aluminium. General specs:
- In very good condition, regularly maintained
- Working zone (axis travel): X=3050 mm, Y=2020, Z=250 mm
- Maximum moving speed: 417mm/sec (X,Y axis)
- Spindle: HSD 7.5kW/28 000 rpm
- Auxiliary head: oscillating tangential knife+creasing wheel+rotating knife+drag knife(also 45deg head)
- Camera module installed
- Touch screen display
- Vacuum table with 6 different manually controlled zones
- Vacuum pumps 7,5kw GARDNER – 2 pcs in separate noise cancelling box
- Automatic tool changer: linear, 6 tools
- CP compressor included with separate noise cancelling box
- Chip vacuum cleaner included (Bernardo DC500E) with separate noise cancelling box
- Computer set included with TypeEdit software
- Separate control box included for switching vacuum pumps and dust collector on low power
Working hours: spindle 1050h and machine-on state 16200h.
Price around 62k€.
info [at] cutit . ee
+372 56 22 26 37
Re: Selling our 2012 Mecanumeric MecaPro 3020 CNC for wood-alu-fabrics cutting
Forgot to add the pictures of it. There they are:
- You may not post replies
- You may not edit your posts
Forum Rules
