Model #C420 Romi Flat Bed CNC Auto lathe NEW (2015) with Siemens 828D CNC control system, conversational and G-Code programming, X-Z ElectronicHandwheel, flood coolant, auto lube, full guard with sliding doors, one piece cast bed, Halogen lamp, pull out chip drawerSpecificationsSwing Over Bed - 16.93”Swing Over Cross Slide - 7 .87”Distance Between Centers** - 39.4”Spindle Taper - MT6Spindle Bore - 2.56”Spindle Speeds - 3-3,000 rpmSpindle Nose - A2-6Cross Slide Travel - 8.7”Tail stock Quill Diameter - 2.36” Tail Quill Travel - 4 5/16”Quill Taper - MT#4Motor (220V/440V) - 10 H.p.Net Weight (lbs.) - 5540Additional Information Options:8” dia. 3-Jaw Chuck Set truTriple bearing live center0- ½ “ cap. Drill chuck with arborCXA Quick change tool post with holdersCradle Follow Rest roller jaws
$34,000
We are upgrading to a larger machine and selling to make room for the new installation.
PM with questions or offer.
Thanks,
Chad
