- Milltronics Partner 7b 1989 needs work $1500 Illinois
I have a Milltronics Partner 7b 1989 I need to move. Centurion IV control. I have not tried to power it up. This one has a full enclosure, and 20pos drum tool changer. CAT40 spindle. 15hp baldor spindle motor. turcite ways. This one will need the ways ground/scraped/turcited. I bought this out of an abandoned machine shop. As far as I can tell this was making parts when it was abandoned. It will probably make parts as is, and would be a cheap way to get into a real machining center. It's 13000lbs, and like 30x16x20 travels.
Id like $1500 as is, or $650 with the controls/servos/ballscrews/spindledrive stripped off it.
I had planned on repowering with linux cnc, but fell into a deal on a bigger machine, so this one has to go.
I can load on your truck.
- You may not post replies
- You may not edit your posts
Forum Rules
