- TREE Journeyman 425 Vertical 3-Axis CNC Knee Mill Milling Machine Dynapath
Condition:
Good - working at time of decommission
Normal wear from age & previous use in working industrial environment.
Regular maintenance performed by previous owner.
Note that the original CRT screen has been replaced by a flat panel screen.
Includes users manuals.
Local pickup only. There is no forklift on site so please bid if you have the means to move this machine (approx 6,000 lbs). Located in Maple Valley, WA.
Make: TREE
Model: Master Journeyman 425 (J425 CNC)
Type: Vertical CNC Knee Mill
Features/Specifications:
Control: Autocon Dynapath Delta CNC w/pendant
Travels:
X-Axis (table): 30"
Y-Axis (saddle): 15"
Z-Axis (quill): 6"
Knee (manual): 17.7"
Throat: 14.8"
Table Size: 12" x 51"
Max. Table Load (centered): 800 lbs
Spindle Motor: 5 HP cont; 7.5 HP, 30 min.
Spindle Speeds: 50-3,500; 50-6,000 RPM
Lubrication system
Coolant system
Dimensions & Weight:
Overall: L 78" (w/stowed control arm) x W 83" x H 86"
Weight: 6,000 lbs (approx.)
TREE Journeyman 425 Vertical 3-Axis CNC Knee Mill Milling Machine Dynapath | eBay
- You may not post replies
- You may not edit your posts
Forum Rules
