If still available can you PM me so we can exchange #'s?
Jon
For Sale: $9800
2013 Novakon Torus Pro Servo edition CNC Milling machine with Upgrades and included Tooling.
Base Mill Specs:
Travel X,Y,X (inches) 22 x 14 x 11.5 (Can be adjusted to 24 x 15 in X and Y travel).
Servo Motors all 3 Axis.
Z Axis equipped with Linear guides. X and Y Axis Dovetail/Gibs
2HP 6000 RPM Spindle.
Computer running Mach 3
~ 2000 lbs with Stand and Enclosure.
Included Options/Upgrades
Power Draw Bar: Can use both TTS and standard R8 threaded tool holders.
Pendant wheel for quick setting of work offsets.
High flow flood cooling.
Change between flood cooling an air blast with panel mounted switch
Custom sheet metal full enclosure
Extra Spindle cartridge
System includes Tormach TTS CNC operator tooling package.
R8 tool holders: ER-32, Side lock 1.2",Face mill Arbor.
I've made 1000's of parts from PEEK, Aluminum, Ultem, and a little stainless steel. The success I've had with this mill has allowed me to purchase a Full Size VMC. I Have a fork lift and can load onto trailer.
Jon
