- NEMA34 1128 oz-in closed-loop stepper Motors 4 Axis CNC Kit (110VAC/220VAC) - No Longer Available
Check Specification:
http://www.automationtechnologiesinc.com/products-page/nema34-closed-loop-stepper-motor-system-hybrid-servo-kit/nema34-1128-oz-in-closed-loop-stepper-motors-4-axis-cnc-kit-110vac220vac
NEMA34 1128 oz-in closed-loop stepper Motors 4 Axis CNC Kit (110VAC/220VAC):
(4) KL-8082H 2-phase Hybrid Servo Driver: 30-80V, 8.2A Peak
(4) NEMA34 Hybrid Servo Motor, KL34-8N-1000, 1/2" Shaft
Rated Torque 1128 oz-in, 8 N-m, with Encoder 1000 line
(4) Three meter encoder cables or longer
(1) KL-7220, 72V(No load), Max 20A,Unregulated Power Supply, 110VAC/220VAC
(1) C10 Breakout board, E-Stop or Limit Switch can be wired
you can update to C11 or any USB breakout board or USB or Ethernet Board
(1) 5V Power Supply for Breakout Board 110VAC/220VAC
List Date: 3/8/2015
For more info, click here to view the original listing: NEMA34 1128 oz-in closed-loop stepper Motors 4 Axis CNC Kit (110VAC/220VAC)
This item is no longer available.
Re: NEMA34 1128 oz-in closed-loop stepper Motors 4 Axis CNC Kit (110VAC/220VAC) - No
- You may not post replies
- You may not edit your posts
Forum Rules
