Run Time Estimation
Results 1 to 7 of 7
Thread: Run Time Estimation
    Default Run Time Estimation
    Anyone have any good tips for improving the Run Time Estimation in NCPlot?
    I can get wildly inaccurate estimations depending on what sort of g-code it is. For example if the file is merely cutting out objects of reasonable size the estimation isn't too far off, but if it is milling something complicated with lots of short moves (such as engraving something.) The actual run time may be 2-3 times what the estimation is.
    Jun 2018
    on my feet
    Default Re: Run Time Estimation
    have you set your rapid speeds in ncplot ?
    I find it gives me a good ballpark estimate on my programs which run anywhere from a half hour to 1.5 hrs . the problem is that it can't take into account for tool changes , accel/decel etc because this varies from machine to machine , otherwise I find it pretty handy for getting an initial cost for machining
    Yes I have set the rapid speeds.
    I know that the problem is primarily acceleration related. but is there any way to compensate for it?
    Or maybe a suggestion for a better program to use for calculating the run time estimates?
    Jun 2018
    on my feet
    The estimates are based on the numbers in the program (distance , feeds and rapids ) , no different from how the cad/cam will calculate the run time . Your not going to find anything other than the control to give you a 100% run time
    I'm not expecting 100% perfect estimations, but when some estimates are within 90-110% of the real run time (which is acceptable), and others are less than 50% of the real run time, it is bordering on useless.
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    hy if estimation is, for example, 33% of real time, then reduce feed to / 3 / 2 ( for example, if initial feed was 0.6, change to 0.1 )
    with such lower feed values, if the new estimation is more accurate ( like it changed from 33% to 70% ), it means that the machine can not reach initial desired feed
    it's annoying, but estimation accuracy decreases for high feed curvy toolpaths / kindly
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
  7. #7
    Member routalot's Avatar
    Dec 2003
    I have used facilities in two other programs that were intended for estimating runtimes.Both were inaccurate,one took no account of the acceleration and deceleration times for each move and assumed instantaneous transition and the other-in the controller-ignored the toolchange times and with a 3 metre long machine,the time from end of a cut needed to travel to the correct location before changing tools and moving to the next location didn't feature in the calculation.After a few jobs it was possible to guess how much to factor in but I wouldn't want to use either to quote for a job.
Run Time Estimation
Run Time Estimation
