Stainless Steel 316 VS 316L Difference
Results 1 to 5 of 5
Thread: Stainless Steel 316 VS 316L Difference
    Default Stainless Steel 316 VS 316L Difference
    Hello,
    316 vs 316L Stainless Steel what's the difference?
    Thank you.
    Member mactec54's Avatar
    Jan 2005
    Default Re: Stainless Steel 316 VS 316L Difference
    Quote Originally Posted by VisionAlloys101 View Post
    Hello,
    Thank you.
    The L = Low Carbon so not much difference apart from that, the L is better for welding
    Mactec54
    Jan 2005
    Quote Originally Posted by langoshin View Post
    and what is the difference between these two and 304?
    Thats a very open question, if you do a Google search you will find what you need
    Here is some information on the (2) material grades
    https://www.rocheindustry.com/304-vs...el_differences
    Mactec54
    Mar 2008
    304 is a pain to machine, in my opinion. It work hardens as you cut it and if you lighten up on the cuts it just turns nasty after a while. in my experience 304 is almost always used in food grade applications and 316 in mechanical applications.
    Bakdum's Avatar
    Sep 2022
    The main difference between 316 vs 316L stainless steel is that 316L has a lower carbon content. This is because 316L has less carbon in it than 316. This makes it more resistant to corrosion.
    The other main difference between 316 vs 316L stainless steel is that 316L is a more affordable option. This is because it has less carbon in it, which makes it less expensive to produce.
