- Newbie- Creating an EGC / Travis Bean style neck
Re: Creating an EGC / Travis Bean style neck
Draw the neck in a cad of your choice.
it is only geometry you create there.
Convert to i.g.e.s from there (wiki the acronym)
Cam stuff is later after the design is complete.
I've done it all, finally, it works in other programs and everything! Don't know why i haven't done this sooner, but here's a link to download it! ^^
https://mega.nz/#!wNhmBaya!0VOWT9l9T...lD4qQ5ruHfxxcg
I am getting it.... got it on screen
a one-piece billet headstock, frets, pickups to bridge design idea?
Also known as - neck thru
model needs more work, have you a physical model ?
have a neck contour selected and dimensions of them?
I see, well, there's no physical model yet, until we are sure it is good. What do you think needs to be worked on? Thanks for the feedback!
Research the neck profile curves, from the usaguitar neck site..com
ah yes i see what you mean, i have designed the wooden inserts that make the profile curve, here they are!
link removed
Here's the body
link removed
Please use igs conversion, the dwgs do not work
- You may not post replies
- You may not edit your posts
Forum Rules
